Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-04-2010, 05:12 PM   #1
Laundry room remodel
I will be remodeling the laundry room next week and I can't decide on tile or just painting the walls. The floor will be tile. I have looked at a few tile stores and everything looks to much like a kitchen. If I do tile the walls how do you trim out the doors and how high would you go up the walls. This room has 3 36" doors and 9' ceilings.
The front loading washer and dryer (I plan to stack them) makes enough vibration that you can feel through the house. I am looking for a way to reduce the vibration. Would isolation blocks do any good? Or, is it better to make the floor more solid by adding mass, as in 3/4 ply, 1/2" cement board and tile. Is there anything I can do to the joists. Sister joists and another beam is not an option but blocking and/or drywall.
Rege
RegeSullivan is offline   Reply With Quote
Old 02-04-2010, 05:24 PM   #2
PHB Construction LLC
Paulie's Avatar
I'm all for a solid floor under a washer and dryer. With that said adding layers also brings up the issue of floor height differences. Nothing your contemplating would be bad. Just a few things. Glue and screw a subfloor. Between the tile board and sub floor, add thin-set. Then screw the tile board down with lots of screws. Use a high grade thin-set for your tiles, don't go cheap.
Paulie is offline   Reply With Quote
Old 02-06-2010, 12:01 AM   #3
sdsester's Avatar
I would think that tile on the walls is just going to make the room bounce around sound even more so I would just paint. Some sort of vibration absorbers/dampers or isolation blocks would not hurt.
Do install automatic shut-off valves while you are at this.
sdsester is offline   Reply With Quote
Old 02-08-2010, 04:56 PM   #4
The automatic shut offs seem so cheaply made I am afraid they will be a maintenance issue. Maintenance as in - replace them often. Because it will be difficult to get at the water supply I hesitate to install one. A neighbor had one of the Watts units that had to be replaced four times in a year and I have heard they may not work with my front loading machine. On the other hand, I am concerned because the convenient shut off will be in the basement while the laundry room in on the first floor so I considered one of the ones with a sensor but my wife tends to get the floor really wet when cleaning it. Do you have an suggestions for a quality unit?
Laundry Room Drain Set-Up - is it okay? bmb2m9 Plumbing 1 02-02-2010 11:49 PM
Laundry room plumbing mikev88 Plumbing 1 01-01-2010 04:10 PM
upstairs laundry room floor - redguard? mazzonetv Building & Construction 6 12-26-2009 10:05 AM
Laundry Room Electrical problem, need help. Twinky Electrical 8 02-27-2008 06:29 AM
Supply and Return from Laundry Room bjstewa HVAC 7 03-03-2007 12:39 AM
