Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-18-2012, 11:12 PM   #1
Laundry room remodel
Hi and thanks for tips. I live in a quad and laundry room is on level where exterior wall is 4ft cinder block and rest wood framing. I gutted walls so I could insulate since this level of house is cold and drafty. The top portion has R-11 and the block portion had nothing. The top is 2x4 and the bottom was 2x2 directly against blocks. I ended up taking the framing out as there was a lot of dry rot in corner. I corrected water issue outside and most of this looks like an old problem. There is some separation between the poured floor and blocks. I will be filling that.
I intend to reframe w 2x4 top and bottom and add insulation floor to ceiling.
My questions - should I reseal the cinder locks? If so- what products have you found work best? Drylok?
Vapor barrier against the cinder block?
Thanks again.
aechabot is offline   Reply With Quote
Need a foundation in my laundry room sweetfarm Building & Construction 14 09-06-2012 10:49 PM
laundry tub in basement laundry room josephmartins Plumbing 11 08-03-2012 07:43 PM
converting laundry room to bathroom brandisophie Plumbing 8 11-07-2010 02:10 PM
Basement laundry room secutanudu Electrical 9 04-23-2010 04:23 PM
Supply and Return from Laundry Room bjstewa HVAC 7 03-03-2007 12:39 AM
