Laundry Room Layout Help? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 12:51 PM   #1
Rewards Points: 97
Laundry room layout help?
I am redoing my laundry and am needing some design help. The pics show the old setup which consisted of a hot water tank (in behind the closet door) next to a raised wahsroom (covering the rest of the wall). The entrance to the crawlspace was a 2'x2' cutout in the washroom itself. I need to come up with some way to have a crawlspace access, toilet/sink, and hot water tank. The toilet piping will also be run under the concrete.
bcbud3 is offline   Reply With Quote
Old 02-12-2010, 01:51 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Okay, I admit I'm blond, but I'm having trouble picturing everything.
Maybe you could provide a bit more information like a scale drawing of the space. Including surrounding rooms may help.
What all do you want to move?
Why?
Where is the crawlspace you need access to and where is your current access?
Your toilet is currently elevated but you want to get rid of the elevation and put it into the concrete slab. Is this correct?
Laundry Room Drain Set-Up - is it okay? bmb2m9 Plumbing 1 02-02-2010 10:49 PM
Renovating the Laundry Room in 7 days newbsauce Project Showcase 4 10-12-2009 11:43 AM
Cabinets in Laundry Room SnowUtopia General DIY Discussions 2 03-07-2008 07:54 AM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 10:35 AM
Supply and Return from Laundry Room bjstewa HVAC 7 03-02-2007 11:39 PM
