#1 |
Last minute dropped ceiling questions - yes more questions :o)
Ok guys, getting close now. Tomorrow morning I plan to do the dropped ceiling on the first room, the office. First, I have one remaining question, I can think of at the moment. I've read, what I believe to be conflicting information on the internet on how to deal with corners. I get the outside corners where i cut the angles at 45 degrees to bend around the corner. But I am a little confused about the inside corners.
There seems to be two opinions on the matter. Method 1 says to "Overlap the wall angle on inside corners" I've attached a picture for method 1 as well. Just looks like they rest one wall angle on top of the other in the corners. Method 2 says "When you come to an inside corner, install the first length of molding tight against the corner and butt the second length against the first." I've attached a picture for method 2 also. Does anyone have any strong opinions over which method might be better? Or doesn't it really matter that much? Seems like Method 2 make the most sense to me, that way that wall angle isn't 1/8 of an inch above the rest. Let me know what you guys think about that. And lastly, I have also attached a picture of my basement plans for the office ceiling. I have also drew in where I planned to place the lights and the one heating vent on the ceiling. The gray boxes are vents on the ceiling, so placing a light in those specific locations is not possible. Can you guys check out my plans to see if they make sense to you? And if there's anything I can improve? The lights are 6" recessed lighting cans. That's the best way I could think to spread apart the lighting. Any thoughts on all this would be appreciated! |
#2 |
Mark,
Your layout looks fine. On the inside corners, you're splitting hairs. I normally overlap the two pieces. The job I just completed, I used a small piece of wooden crown instead of the steel wall angle. Looks a lot nicer. They also make outside corners that snap over the two cut pieces if like. Mike Hawkins
#3 |
Drywall contractor
Are any of the walls exterior with windows or doors? Heat supplies generally are placed near exterior walls and close to the door. Reasoning I guess is it will be colder/hotter on an exterior wall due to outside temps. Just something to consider, not an absolute. Lighting plan looks good. I overlap inside corners.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
#4 |
Remodeler
Mark, it all looks good. It isnt that easy to miter these corners. The channel isn't 1/8" so just lay them on top of the other (overlap) the difference is not notable except to you :-)
Go for it. The lighting looks good. Can lights will give some down light but not allot of overall. Plan on some other lighting. Florescent while some people don't like them do give more light overall. If you have done this already today I am sure it came out nice. If not have fun.
Minichillo's Construction I will never leave you hanging! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
Where is the entrance into the room? I usually like to center a light on the entrance when possible. I always ask for the miter corner, no reason why the overlap wouldn't work but the miter looks more "clean" to me.
| Display Modes | |
| Tongue and Groove Ceiling install....questions... | Dr. Jim | Remodeling | 9 | 04-08-2012 01:14 PM |
| Drywall ceiling: Water Damage, looking for advice | dawho1 | Building & Construction | 11 | 09-13-2010 11:05 AM |
| Is it advisible to insulate under a ceiling | Karsten | Building & Construction | 2 | 12-13-2009 06:23 PM |
| Questions about re-routing ducts in ceiling. Please help! | xe0s | HVAC | 6 | 04-30-2008 08:38 PM |
| Pot lights in a drop ceiling | Howdy | Electrical | 3 | 03-14-2008 09:23 PM |
