Large Notches In Floor Joists - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 09:58 AM   #1
Large Notches in Floor Joists
I recently uncovered a few floor joists that have been severally notched around some piping. I'm looking for suggestions as to the most appropriate way to reinforce them. The floor above is attic space, but I'd prefer to make it structurally sound before I close it all back in.
R.P. is offline   Reply With Quote
Old 09-21-2012, 10:10 AM   #2
Rewards Points: 12,840
Going to have to cut the joist and add a double up header on both ends to support the joist.
This would also be the perfect time to take the time to cut and remove all that old steel piping.
At some point it is going to leak and plug up and that whole area would have to be opened up again to fix it.
Old 09-23-2012, 10:45 PM   #3
homeprova's Avatar
Do not cut anymore of the floor joist! The general repair for this is to measure the current cutout ( example: it's 4 feet wide), the repair would be the same size floor joist nailed, glued, and bolted exactly 12 foot long being the left and right having the same cut out distance. 4 foot left, 4 foot center, and 4 foot right = 12 ft total length of repair. If you don't have room to scab the repair, the only choice you have is a full removal of the truss and a new one installed
Good luck!!
homeprova is offline   Reply With Quote
Old 09-23-2012, 11:10 PM   #4
And what good would sistering do when it alos would have to be cut to fit the pipes.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
12penny (09-24-2012), oh'mike (09-24-2012)
Old 09-24-2012, 04:58 AM   #5
DIY staff
Rewards Points: 7,174
Could you remove the cast iron vents and replace them with PVC ? If that's an attic you could raise them above the joist and sister in a full replacement.
Old 09-24-2012, 05:17 AM   #6
DIY staff
Another thought----Sister in a full joist on the first available space (to the right of the pipes in the photo)
Then add two saddle beams from the doubled joist --back to the wall and hang the cut joists off the saddle beams.
A similar suggestion would be to frame that like a stairway opening---
Move the pipes---much easier----
Need ideas for large, multi-space living room D-Lew Interior Decorating 2 01-03-2012 01:26 PM
Unused large central closet to become Laundry room. Soupcatcher Plumbing 1 08-06-2010 05:01 AM
redecorating a large wide 1950's bungalow hallway HOLLYROSE Interior Decorating 1 12-01-2009 01:14 AM
large mystery plywood panel in garage - any thoughts on this?! joeyboy General DIY Discussions 15 12-02-2007 04:01 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
