Laminate Flooring Over A Slab - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-22-2012, 02:39 PM   #1
laminate flooring over a slab
What is the best sub flooring to use on a slab? I have friend that swear by plywood for insulation.
charles turner is offline   Reply With Quote
Old 05-22-2012, 05:01 PM   #2
Rewards Points: 512
just throw some of this down and call it a day. http://www.aquastep.be/en/aqua-step-collection-wood/ if you do go with a subfloor i say use dricore, some on here will say not to use osb on concrete but it is roughly an inch off the ground and if iys getting wet then you have major problems and will have to be removed anyways
princelake is offline   Reply With Quote
Old 05-22-2012, 05:44 PM   #3
Rewards Points: 13,458
Has a moisture test been done on the floor?
If the floor is dry and you can stand the room to have it raised I've used 3/4 blue foam tape the seams the go over that with 3/4" T & G Advantec Tap Coned to the slab. Then you can install all most any floor you want.
I would not use lamnite right over a slab, use endineered flooring instead.
It can be installed just like a flaoting floor by gluing the seams but is far more stable the laminite.
Old 05-23-2012, 08:19 PM   #4
Rewards Points: 512
dont want to hijack this thread but how do you test the moisture content of a slab? theres always moisture in the concrete and if you put a moisture meter on it the meter will read high.
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Laminate Flooring Installation - Guesstimate This Job For Me Please flowerchick Flooring 8 11-19-2011 12:57 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Laminate flooring to concrete abndaddy1994 Flooring 2 02-06-2010 08:26 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
