-   -   laminate flooring over a slab (http://www.diychatroom.com/f15/laminate-flooring-over-slab-144537/)
charles turner 05-22-2012 02:39 PM
What is the best sub flooring to use on a slab? I have friend that swear by plywood for insulation.
princelake 05-22-2012 05:01 PM
just throw some of this down and call it a day. http://www.aquastep.be/en/aqua-step-collection-wood/ if you do go with a subfloor i say use dricore, some on here will say not to use osb on concrete but it is roughly an inch off the ground and if iys getting wet then you have major problems and will have to be removed anyways
joecaption 05-22-2012 05:44 PM
Has a moisture test been done on the floor?
If the floor is dry and you can stand the room to have it raised I've used 3/4 blue foam tape the seams the go over that with 3/4" T & G Advantec Tap Coned to the slab. Then you can install all most any floor you want.
I would not use lamnite right over a slab, use endineered flooring instead.
It can be installed just like a flaoting floor by gluing the seams but is far more stable the laminite.
princelake 05-23-2012 08:19 PM
dont want to hijack this thread but how do you test the moisture content of a slab? theres always moisture in the concrete and if you put a moisture meter on it the meter will read high.
