-   -   Laminate Floating kitchen floor/cabinet install (http://www.diychatroom.com/f15/laminate-floating-kitchen-floor-cabinet-install-14300/)
kearnsj 12-11-2007 11:21 AM
I am planning a kitchen remodel and will not be putting the laminate floating floor under the cabinets, but planned on putting it under the appliances to make moving them in and out easy.
Do I need to put anything under the base cabinets to account for that height difference presented by the floor or should I just measure 34 1/2" from the subfloor to determine my base and wall cabinet height?
RTRCon 12-12-2007 09:21 AM
You want to be 34 1/2" off your finished floor height so you wont have any problems fitting dishwasher, wine cooler or other under counter appliances. Set you cabs on blocks to bring them up to you hardwood height.
kearnsj 12-12-2007 09:34 AM
Thanks. Should I install the floating floor under the appliances so that visually I see the finished floor and not the subfloor, especially for the refridge., which will jut put from the 24" side panels? Or should it be a combination of the floating floor and additional subfloor to make the height the same?
Cole 12-12-2007 10:50 AM
Its your call, either will work.
Handyman50 12-14-2007 05:33 PM
The only appliance that I didn't sit on top of my laminate flooring was the dishwasher. It has a panel that comes down to the flooring so you can't see the substrate. I did, however, caulk heavily at the edge of the flooring with a high quality silicone caulk.
Caulk should be used around the perimeter of the flooring, also. Most manufacturers recommend 1/4" - 1/2" between the flooring and the walls or cabinets.
AtlanticWBConst. 12-14-2007 07:44 PM
Good suggestion: all perimeter areas should be siliconed in a kitchen application.
In fact, most manufacture's stipulate it as part of their warranty requirements (in bathroom and kitchen laminate installations)
Handyman50 12-17-2007 04:04 PM
This is correct. I just got through installing laminate flooring in a small bathroom. The manufacturer recommends 1/4" gap between the flooring and the wall and cabinets for under 1000 sq. ft. and 1/2" for over 1000 sq. ft. I used 1/4" since I only had 32 sq. ft. A whopper. Huh?:laughing: As I stated, I also used a different brand of laminate in the kitchen and the instructions were the same.
I used GE, Bath & Kitchen Silicon ll (Clear) in the gaps. It becomes solid, but it is still flexible.
