Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-21-2010, 02:24 AM   #1
laminate counter tops
can you ceramic tile over laminate counters
kimmers is offline   Reply With Quote
Old 06-21-2010, 06:42 AM   #2
Yes, but you need to rough up the surface so the thinset/adhesive has something to bite onto. And thoroughly clean to remove grease, dust.
The Following User Says Thank You to Just Bill For This Useful Post:
kimmers (06-22-2010)
Old 08-04-2010, 11:41 AM   #3
gmhammes's Avatar
any pictures, i would like to see how they came out!
gmhammes is offline   Reply With Quote
Old 08-12-2010, 04:37 AM   #4
First of all,you should inspect your countertop for signs of peeling, or bubbles in the laminate,before starting tiling on it. Now,sand down the laminate lightly to remove the gloss and to make the surface rough. after this,you can spread the grout mortar over the laminate and insert tiles in the desired pattern.
johnmwentz is offline   Reply With Quote
Old 08-12-2010, 09:41 AM   #5
jlhaslip's Avatar
Yes, but I would not do it.
The better method would be to remove the Laminate top and rebuild it using pressure treated plywood topped with cement board, in my humble opinion.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
BigJim (08-12-2010)
Old 08-27-2010, 12:32 AM   #6
Are your base cabinets solid and support the current countertops well?
What you need to be concerned with is deflection of the tile, will you have teenagers sitting on the counters, etc... tile and the cement board will add a good amount of weight.
Jl is right though I have done successful installs with adding bracing to limit the deflection from under the base cabinets, thinset and screwed in 1/4" cement board.
gjjr2001 is offline   Reply With Quote
Laminate Counter Tops, clear coat? joedreamliner787 Painting 9 06-16-2011 04:55 PM
Corian or Granite counter tops Jms92 General Discussion 21 04-17-2010 07:18 PM
laminating counter tops ponch37300 Remodeling 3 05-13-2009 11:13 PM
attaching countertop analogmusicman General Discussion 22 08-10-2008 12:53 PM
Applying laminate to waterfall edge on a counter top. lmpasker Carpentry 2 04-02-2008 07:34 PM
