-   -   laminate counter tops (http://www.diychatroom.com/f15/laminate-counter-tops-74234/)
kimmers 06-21-2010 02:24 AM
can you ceramic tile over laminate counters
Just Bill 06-21-2010 06:42 AM
Yes, but you need to rough up the surface so the thinset/adhesive has something to bite onto. And thoroughly clean to remove grease, dust.
gmhammes 08-04-2010 11:41 AM
any pictures, i would like to see how they came out!
johnmwentz 08-12-2010 04:37 AM
First of all,you should inspect your countertop for signs of peeling, or bubbles in the laminate,before starting tiling on it. Now,sand down the laminate lightly to remove the gloss and to make the surface rough. after this,you can spread the grout mortar over the laminate and insert tiles in the desired pattern. :icon_lol:
jlhaslip 08-12-2010 09:41 AM
Yes, but I would not do it.
The better method would be to remove the Laminate top and rebuild it using pressure treated plywood topped with cement board, in my humble opinion.
gjjr2001 08-27-2010 12:32 AM
Are your base cabinets solid and support the current countertops well?
What you need to be concerned with is deflection of the tile, will you have teenagers sitting on the counters, etc... tile and the cement board will add a good amount of weight.
Jl is right though I have done successful installs with adding bracing to limit the deflection from under the base cabinets, thinset and screwed in 1/4" cement board.
