Knocking Down A Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 12:42 AM   #1
knocking down a wall
how to knock down a wall?
christinamartin is offline   Reply With Quote
Old 09-29-2012, 05:13 AM   #2
Too Short? Cut it Again!
What kind of wall. Is it load bearing and holding all or part of your house up?
Old 09-29-2012, 05:28 AM   #3
DIY staff
Rewards Points: 7,174
I saw a truck do that once----not a clean job though.
A few more details---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
mae-ling (11-07-2012), woodworkbykirk (09-29-2012)
Old 09-29-2012, 07:34 AM   #4
Rewards Points: 13,706
#1 You have to figure out of it's load bearing.
#2 Find out is there's any wiring, plumbing, HVAC ducts inside the wall.
Is it an inside or outside wall?
Old 09-29-2012, 11:49 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
you do it by hiring a pro... if you dont know how.. dont do it
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
user1007 (09-29-2012)
Old 09-29-2012, 01:21 PM   #6
True story. One of my best friends used to build very high end residences in an affluent neighborhood or two in Northern California. He once put an offer on a house that had a couple mortgages and a construction loan attached to it. It was clear the bank had never checked up because the DIYers had removed bearing walls, the house had collapsed, and the homeowners had just walked away from it. He was going to raise and build a new home anyhow so it didn't matter to him but we had to laugh about it. The people destroyed what was probably a home in the $350K range. He built something about 3 times that which of course amounted to about 400sf in N California of course.
Lesson is make sure you know what you are taking down and how to do it. As mentioned above, if you are not sure pay someone to do it.
Old 11-07-2012, 08:00 AM   #7
Use a sledge hammer cause its the basic tools to do it but it also depends on what type of wall it is...
Carmen Bretto is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 10:28 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
