Kitchen Wall Removal - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-08-2013, 12:05 PM   #1
Rewards Points: 18
Question
Kitchen wall removal
Hi guys. I'm remodeling an older house with a galley kitchen that was added as an addition after the original build. The dimensions of the room are 14' x 7' with a wall that separates the kitchen from a set of stairs leading to the basement. I've torn out the stairs with the idea that removing this wall and adding a floor would give me much needed space for the kitchen, making it 14' x 10'. Is it okay to remove this wall without adding a beam in its place since the span of 10' seems short enough to me? Thoughts?
Thanks!!
bdunk is offline   Reply With Quote
Old 08-08-2013, 02:17 PM   #2
Rewards Points: 13,468
How would we even be able to guess without at least some pictures, drawings, something.
No way would I count on any on any web site sizing the beam for you.
You really needed to have someone that knows what, such as an engineer there doing on site before even starting this. They also would be able to spec. not just guess as to what size and type beam was needed.
Old 08-08-2013, 02:49 PM   #3
Rewards Points: 18
Thanks. I'm just trying to get an idea if a beam will even be needed. I can post some pictures, but I guess I thought the dimensions would be sufficient. Let me rephrase the question: Do I need a support beam in a room that is 14' x 10' ?
Old 08-08-2013, 04:47 PM   #4
Still not going to do any good.
No one knows what's above this room, what style roof and rafters you have, ECT.
Just a whole lot more to it then just ripping out walls.
Almost every older home I've came across needs to have major reconstruction from some home owner removing walls on the first floor just to "open" things up.
Old 08-08-2013, 04:51 PM   #5
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 976
It's not only this but the stairs must also be relocated and engineered for the new floor opening.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 08-08-2013, 06:04 PM   #6
DIY staff
Rewards Points: 7,174
You mentioned that the galley kitchen was added on to the outside of the house---this means it is likely that the wall is a bearing wall--so the removal will mean adding a beam engineered for the load---
Get someone on site with structural knowledge---Mike----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
mae-ling (08-14-2013), Oso954 (08-10-2013)
Old 08-09-2013, 11:40 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
one-story or two-story home?
I agree with Mike, if we have to guess then the guess would be a beam would be needed based upon the span of the beam, the load it must support and the material the beam is made from.
some photos and additional information (after viewing photos) may get your better answers.
Structural remodelling is best left up to design professionals with knowledge and experience in doing such.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-13-2013, 07:32 PM   #8
Rewards Points: 18
Thanks guys, I appreciate the input. While Ive never built a home from scratch I have completed several structural projects with relative success. I've always gone above and beyond what is required to do the job. In this case, hiring a 'structural expert' would cost me exponentially more money than the $200 I've spent to successfully complete this project. 6x6 posts supporting a 14' long 4" wide lvl. Works like a dream and didnt break me.. On to the next. Thanks!
The Following 2 Users Say Thank You to bdunk For This Useful Post:
mae-ling (08-14-2013), oh'mike (08-14-2013)
Load bearing wall removal abjkkc Building & Construction 17 10-03-2012 10:49 AM
Load bearing wall removal marquez29 Carpentry 16 03-30-2009 12:34 PM
Removal of interior wall Bobb G Remodeling 4 09-15-2008 01:30 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
