Kitchen Tile Backsplash Trim - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 06:21 PM   #1
Kitchen tile backsplash trim
Remodeling kitchen -does ceramic tile backsplash go under window trim or does it butt up to window trim? Tile first or trim first?
Janer is offline   Reply With Quote
Old 01-18-2011, 07:35 AM   #2
Usually, I run the tile up to the bottom of the sill and skip the trim. If for some reason the trim stays, I go under the trim slightly(hard to nail thru tile).
Old 01-18-2011, 10:33 AM   #3
Rewards Points: 5,336
I usually use a two piece trim around the window. I install the main trim piece first( say a 2 1/2" colonial casing). Then I rabit a backband piece and install that. The tile slides into the rabit notch. This way the casing sits in front of the tile.
Ron
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 07:47 PM
Tile 911, Kitchen Kara75 Flooring 0 11-13-2010 09:04 PM
Tile Membrane behind kitchen back-splash? ChrisDIY Kitchen & Bath Remodeling 4 04-29-2010 12:08 PM
Two Questions about Kitchen Wall Tile sbazzle Kitchen & Bath Remodeling 15 04-23-2010 09:59 AM
Kitchen tile backsplash?? momof2labs Tiling, ceramics, marble 3 02-24-2010 07:29 AM
