Kitchen Reno - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-12-2014, 07:07 AM   #1
Kitchen Reno
I am starting a kitchen renovation and thinking I will do it in stages. Needs new everything and then will be a rental-so needs to be done nicely but not my own kitchen.
i am living in the unit and the old vinyl floor is horrible-holes etc. I would like to start there but wanted to know if that is a bad idea-can i put down new laminate flooring and then replace the cabinets?
Thanks.
shogan is offline   Reply With Quote
Old 02-12-2014, 07:36 AM   #2
If you are thinking of doing it in stages,I am thinking you are single!
Marbledust is offline   Reply With Quote
Old 02-12-2014, 07:50 AM   #3
Ok creepy
Old 02-12-2014, 07:56 AM   #4
DIY staff
Rewards Points: 7,174
The trouble with 'doing it in stages' is this----
A kitchen demo--rebuild--is a bit messy--and there is an order to the process---
Here is the typical order of things---
Design-
Demo of cabinets,flooring and drywall in the back splash area,
Mechanical---upgrade electrical-add can lights/under cabinet light wiring--new wiring for microwave--
Replace T- for the sink--perhaps lower it if needed.
Replace drywall and tape/sand--prime--
Install flooring
Install cabinets and base moldings
Install appliances
Paint---
I don't see how you can do a kitchen 'in stages' without demoing it first---
Floor goes under the cabinets in an ideal situation---new cabinets might not have the same foot print as the old ones---so floor first would be a mistake.
How were you thinking of doing it?
shogan (02-14-2014)
Old 02-12-2014, 08:01 AM   #5
DIY staff
I suspect this tongue in cheek comment was aimed at the long dragged out mess--and marital discord----a gut and remodel is relatively fast.
Dragging out the job by doing it 'in stages' could make a mess of the kitchen for months----
Old 02-12-2014, 11:57 AM   #6
MarginallyQualified
Rewards Points: 2,464
Originally Posted by oh'mike View Post
Dragging out the job by doing it 'in stages' (edit: WILL) make a mess of the kitchen for months----
And every other room and space near the work area.
Bite the bullet or wait until you can bite (and swallow) the bullet.
As to the "maybe make it a rental later" thing be VERY careful to not build beyond your market. Choose materials and layout based on ease of maintenance and most universal appeal --NOT what you might like best.
The Following User Says Thank You to TarheelTerp For This Useful Post:
shogan (02-14-2014)
Tags
flooring , kitchen renovation
Kitchen floor tiles. ABurch Kitchen & Bath Remodeling 1 12-06-2012 01:35 PM
Harwood in a Galley Kitchen Parallel to the Joists? David Osinga Flooring 8 12-05-2012 06:38 AM
Kitchen reno, any better suggestions? mgarfield Remodeling 7 01-20-2010 04:37 PM
My first kitchen reno....any tips? avro1 Remodeling 2 01-19-2010 10:49 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
