Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-24-2012, 06:07 PM   #1
kitchen remodel order
Here is my situation:
Total kitchen remodel.
Wall cabinets in- Base cabinets in place but not screwed to wall.
Appliances arrived (in garage)
Looking for a general order to go from here.
Do I screw all base cabinets in and then slide dishwasher/oven in- or start on one end ans work my way down? In other words- get dishwasher hooked up and then screw sink cabinet to wall etc? then work my way down to stove? Just want to make sure if I need to move something a fraction or so- I still can to accomodate appliances.
Huskyfan68 is offline   Reply With Quote
Old 11-24-2012, 06:16 PM   #2
Are all the walls painted before the cabinets went in?
Who designed this layout?
In most cases you start in the corners and work your way way out.
Without seeing what exactly you have it's hand to suggest a whole lot.
Do you have cabinet clamps.
Have you marked where the studs are?
Do you have cabinet screws?
Old 11-24-2012, 07:05 PM   #3
Super Moderator
I like to mount the uppers first so I don't have to work over the base cabinets---but that is not a 'must do'
First step is to establish the high point in the floor----using the longest level you have--determine the high spot---mark a line on the wall 34 1/2" above that spot--(check the height of your base cabinets in case your cabinets are not 34 1/2")
Snap a level line using that mark----this is what you will use to level the cabinets---start in a corner--lazy Suzann if you have one---
Start champing the face frames together and pre drilling and screwing the cabinets together---the doors must be removed so be careful not to mix them up----shim the bottoms and screw the backs to the wall using your snapped line---when you get to the dishwasher hole----
DW is 24" wide opening----if you are smart you will cut two 24" wide spacer sticks---add a longer stick on top of that---then clamp the spacer to the cabinets----it's a common error to have that opening shift and ruin your installation,
Check your walls for plumb before you start----coping the cabinets or a filler might be needed to keep the cabinets level against a crooked wall.
joecaption (11-24-2012)
Old 11-24-2012, 07:06 PM   #4
paint first if you haven't. start in a corner like joe said. its easier if you mark all the studs first then you can put the cabinets in easier and faster. usually the floor is done before appliances go in. some people prefer to do the floor before the cabinets. i raised all my cabinets up 3/4 of an inch to compensate for the tile floor i was installing. always check your floor to find the lowest and highest spot. if you start at the highest spot you can shim the other cabinets up to that level. if you start at the low point you will be ripping the toe kick off to get the cabinets level. if you measure up at the high point and strike a level line around the wall you have a reference point for all of the cabinets.
Old 11-24-2012, 07:09 PM   #5
Like Oh'mike said establish the high spot of the floor first!
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 11-25-2012, 04:12 PM   #6
remember the 24" for d/w is measured from the lip of the cabinets ,and not the body
terry603 is offline   Reply With Quote
The Following User Says Thank You to terry603 For This Useful Post:
oh'mike (11-30-2012)
1930s Kitchen Remodel zeldarizona Painting 17 08-26-2011 05:41 AM
Kitchen remodel ideas/design needed, with PICs amdspitfire Kitchen & Bath Remodeling 4 04-16-2011 10:11 AM
Kitchen remodel advice J187 Remodeling 7 11-15-2010 03:47 PM
Kitchen Remodel - 101 allen1466 Remodeling 5 06-22-2007 09:56 AM
