Kitchen Cabinets, Can I Find Inside Hinges For These? Pictures Inside - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 09:53 AM   #1
Kitchen cabinets, can I find inside hinges for these? Pictures inside
Hi everyone,
I'm sanding and painting the cabinets today per the wife's orders. Question is, can I find hinges that are inside the cabinet completely anywhere? I tried at Lowes and Home Depot, nothing worked.
www.imgur.com/5g7rM
This is what they look like, there's probably a word to describe them that would make this a lot easier...
Mr.Burns is offline   Reply With Quote
Old 01-01-2013, 10:14 AM   #2
Rewards Points: 12,802
Confusing post, are you just trying to replace what you have with the same style hindge?
Or changing them to a differant style?
What you have now is offset hindges. there's at least 3, differant offset depths.
If your look to change to a differant style I think you mean something like these.
http://www.hardwaresource.com/hinges...-+Blum+Hinges/
Mr.Burns (01-01-2013)
Old 01-01-2013, 10:20 AM   #3
Sorry to be confusing.
This is the outside of the cabinet, www.imgur.com/yFjBB
You're right on with the link, that's what she wants. Thanks, hopefully looking around on that site I can find something. The common ones don't work due to the way the doors were made, the first picture shows what I'm trying to explain.
Happy New Year!
Old 01-01-2013, 10:22 AM   #4
DIY staff
Rewards Points: 7,174
If you want 'hidden hinges' that are inside of the cabinet---your best bet is 'European style' hinges-----these need to be set into a hole in the back side of the door---
To do the installation you need a drill press and a Forsner bit----not to difficult---but only a foolish person would attempt that without a drill press---the pocket hole might go right through the face of the door of this was attempted using a hand held drill.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
dougp23 (01-09-2013), Mr.Burns (01-01-2013)
Old 01-01-2013, 10:26 AM   #5
DIY staff
If you have a Woodcraft or Rockler store near by, they have a huge supply of different hinges---
Old 01-01-2013, 10:34 AM   #6
Thanks for the tips Mike and Joe. The website Joe posted is good, but I think I'll just bring a small door to a place like you said Mike. I don't want to bother thinking I have the dimensions right and come home with the wrong thing.
The problem we had originally is the design of the doors doesn't lend itself to boring a hole for the european style, at least the narrow selection at Lowes. Can you guys tell from the first picture if it's possible? I hope that a good hardware store would have enough to pick from that there's something out there for this style of door.
And now I'm regretting not buying that guy's drill press on craiglist two months ago, even though I have no cause to do it back then ha
Old 01-01-2013, 10:45 AM   #7
DIY staff
Blume and others make hinges for that style of door---
Also---there are lots of cabinet door companies that will make doors and drawer fronts at very reasonable cost----Google --Cabinet door manufacturers--
Old 01-01-2013, 10:48 AM   #8
My be cheaper to just find a local cabinet shop and let them bore the holes for you.
Old 01-01-2013, 01:49 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Maybe I have been out of the business too long but I didn't know anyone made offset European hinges. 3/8 inch is too much to set the hole back in unless part of the hole is on the 3/8 inch offset, which might work, hmmmm got to think about that one, wait, where would the screws go. Nope wouldn't work, the part that goes in the 32mm hole will hit the edge of the face frame, unless someone has designed a hinge that will work just for that type door.
Man I sound like an ole man don't I, .
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Mr.Burns (01-09-2013)
Old 01-01-2013, 04:39 PM   #10
DIY staff
There are European hinges for inset doors---those might work---
Old 01-01-2013, 04:53 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
I think you are right, they might but how would the hinge react not closing all the way? Just a thought.
Jim
The Following 2 Users Say Thank You to BigJim For This Useful Post:
Mr.Burns (01-09-2013), oh'mike (01-01-2013)
Old 01-02-2013, 04:16 PM   #12
Mold!! Let's kill it!
Rewards Points: 2,012
What you've got now is a 3/8" offset, half surface hinge. You could go to a 3/8" offset concealed hinge. The only thing that would show is the knuckle of the hinge. You're going to have to patch the screw holes no matter whether you use those or the euro-hinges.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Old 01-09-2013, 11:52 AM   #13
Thanks for the replies everyone. After testing a few more hinges of I think Maintenance 6 is right, the best bet is minimally exposed hinges.
Regardless, the house is from 1913 and the cabinets were built by the previous owner, so this look will work. Already have them sanded, primed, and first coat of white on
The Following User Says Thank You to Mr.Burns For This Useful Post:
oh'mike (01-09-2013)
Old 01-11-2013, 08:30 AM   #14
Rewards Points: 318
Those hinges look like they are spring loaded (little box behind the face) so they stay closed by themselves. Are there some kind of latches also? Many kinds of hinges came and went, and same kind of spring loaded hinges, if that, may not be available.
carpdad is offline   Reply With Quote
Old 01-11-2013, 11:50 PM   #15
oh'mike, I have used this tool successfully many times. Check it out. No drill press required.http://www.rockler.com/product.cfm?p...0&site=ROCKLER
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 07:14 PM
lay travertine floor or install kitchen cabinets first? palacenil Flooring 31 07-28-2010 11:42 PM
Upgrade inside kitchen cabinets WATSONJ Kitchen & Bath Remodeling 2 01-03-2009 01:22 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
