Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-17-2005, 08:49 PM   #1
Question
kitchen blues
need too drywall kitchen area were there was once tile that was place directly on the wall also need to hang new kichen cabinets I am a beginner please also tell me how too cut sheet rock
mickey is offline   Reply With Quote
Old 09-17-2005, 10:00 PM   #2
jproffer's Avatar
kitchen blues
Well, you can't hang the cabinets until you get the rock up and finished, so let's start with that.
If the walls aren't down to bare studs, get them that way. Drive in or pull out ALLLLL the nails, insulate as needed and now you're ready to rock . OK, I would suggest hanging horizontally. I would also suggest getting rock long enough and wide enough to cover each wall with only 2 sheets (one seam). Sometimes, obviously, this isn't possible, but if your wall (any given wall) is less than 12 feet long, and less than 9 feet high (yes nine, that's not a typo. I didn't mean eight ), you can rock it with 2 sheets. They make 12 foot drywall, available at any self respecting lumber yard. I would recommend against a homeowner and a buddy or 2 trying to hang more than 12 foot rock. They also make what's known commonly as "stretch rock", it's 54" wide (instead of 48), making it possible to rock to a 9 foot lid with only one seam. The stretch is a little harder to find (read that as: you won't find that at the big box. Go to a REAL lumber yard.) Well, that'l do for now.
HOMEWORK :D : Post back room dimensions, lid height, and shop around and see what lengths rock are available in your area, and also if stretch rock is available.
We'll get to the cutting and hanging after you have materials on site. One step at a time, this isn't going to happen overnight no matter what you do, and definately not if we rush things and I/we over-assume. You'll end up doing it twice or three times.
In reading that I guess I may need to explain one term I used that may be puzzling (or may not). Anyway, "lid" is the ceiling. I'm sure you would have figured it out, but now ya don't have to. :D
jproffer is offline   Reply With Quote
Old 10-03-2005, 03:23 PM   #3
kitchen blues
Mickey,
Cutting the sheetrock is the easy bit. Score the face with a utility knife, give it a knock with your knee on the back side and it will break clean. Take the knife again and cut the paper backing. Taping and finishing is the big trick. Horizontal seam is the way to go but the corners are tricky.
'Andyman is offline   Reply With Quote
Old 10-04-2005, 07:51 AM   #4
aka:awesomedell
Send a message via MSN to housedocs
kitchen blues
You won't find stretch rock in most lumber yards either unless it is special ordered, you will need to find a drywall supply yard in your area.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Insulation under kitchen addition rubicon789 Carpentry 11 01-26-2007 04:24 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
got rid of kitchen island, how to get rid of the electrical wire from floor ckcrew Electrical 15 12-14-2006 10:45 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 08:17 PM
