Kitchen Backsplash - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 09:19 PM   #1
Kitchen Backsplash
This is probably a stupid question... I have a granite countertops and the same granite flows up the wall. I would like to install different backsplash, but don't want to do it if I'm going to have to remove the existing granite on the wall. That sounds expensive and not easy to do. to Is that even possible? Would it looks funny to put tile backsplash on top of granite backsplash? Thank you in advance for any insight!
djs7d is offline   Reply With Quote
Old 01-30-2012, 09:26 PM   #2
Rewards Points: 12,808
One reason not to, how do you plan on finishing the outside edge on the end?
Show us a picture of what you have to see what looks so bad you need to change it.
Old 01-30-2012, 09:30 PM   #3
It doesn't look so bad, but If I could add a splash of color instead of the black granite countertops with black granite backsplash I'd like to...
kitchen backsplash subway tile deborah dempsey Building & Construction 6 12-03-2011 07:20 PM
help! bring my kitchen together NewlywedKristin Interior Decorating 10 10-26-2011 02:08 PM
10x10 Kitchen Set Work in this Kitchen ryanb4614 Remodeling 3 08-25-2011 08:48 PM
removal of laminate kitchen backsplash kjeffer Building & Construction 2 08-23-2011 09:48 AM
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 06:05 PM
