Kerdi Or KBRS Shower Seal Over Silicone? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 07:27 PM   #1
Kerdi or KBRS Shower Seal over Silicone?
I just finished putting up my backerboard around my shower pan this weekend. According to the instructions with my shower pan, I put a bead of 100% silicone caulk between the base and the bottom of the backerboard. Unfortunately, a fair amount of silicone seeped out and dried up along the perimeter of my shower base. I've scrapped some of it away, but it's almost impossible. There is a thin coat of silicone all along the shower base and where it meets the backer board. My question is, can I put a waterproof membrane (KBRS Shower Seal which is similar to redgard) over the silicone and or a kerdi band around the perimiter before i tile? I'm concerned that either/or will not adequately stick. Or should I just go ahead an start tiling with thinset and assume it's good. I was originally planning to use the shower seal along the gap, but now I'm not sure that's going to work.
Any suggestions?
Thanks in advance...
cobrakai is offline   Reply With Quote
Old 11-30-2010, 11:19 AM   #2
Rewards Points: 5,336
You would contact the manufacturer of whatever product you're going to use and ask them about the compatibility of the products involved.
Ron
Old 12-01-2010, 09:29 AM   #3
www.No-Curb.com
JohnFRWhipple's Avatar
Sealing the backer board to the shower pan
This is a weak connection point for most showers.
I would suggest you use a little piece of Kerdi, Nobel TS or equivelant and apply the membrane to the shower base with Nobel 150 or Kerdi fix. Attach the Kerdi to the CBU with non modified thinset or the Nobel TS with modified or un modified thinset.
Did you add any poly or such behind your CBU?
IS this shower a steamer?
Do you wish to further waterproof the shower?
Can you post pictures?
Good luck.
JW
JohnFRWhipple is offline   Reply With Quote
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 37 06-05-2017 05:19 PM
How to properly seal window in tiled shower stall. Proby Kitchen & Bath Remodeling 0 07-21-2010 11:49 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Kerdi Basement Shower ldogg Flooring 7 09-13-2009 08:28 PM
