Joint Compound For A Floor - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-30-2013, 09:30 AM   #1
Question
joint compound for a floor
this will sound crazy but, I am one of "those" people I recently added a faux rock wall using joint compound...applied 1/4" thick or so carving in the "grout lines" with the end of a paint brush and finishing with several paint colors... I love the way it turned out so I was thinking of doing my floor. Is this a possibility it will have heavy use and I do plan on using a heavy poly coat just not sure how it will stand up over time
kndmercer is offline   Reply With Quote
Old 08-30-2013, 01:26 PM   #2
Rewards Points: 2,240
If you mean "joint compound" - as in - drywall, joint compound -
not a good idea!
If you mean "joint compound" - as in - mortar(bricks) -
not a good idea!
rossfingal
rossfingal is offline   Reply With Quote
Old 08-30-2013, 03:17 PM   #3
Bill Kearney
Rewards Points: 1,174
It won't stand up. It'll crush like powder.
If you want a rustic stone look on your floor then using material intended for the purpose. There are a ton of materials for this, porcelain can be had in hundreds of variations that don't look like plain old square tile.
Be sure to factor both travel AND cleaning when considering flooring. You don't want to set up something that's going to be uncomfortable to walk upon. Or worse, cause tripping hazards. Then consider what it'd take to keep it clean. Some materials fare worse than others depending on the type and amount of traffic upon them.
wkearney99 is offline   Reply With Quote
Old 08-30-2013, 07:19 PM   #4
Rewards Points: 3,130
Stand by: the slightest wall movement whatsoever and your "faux rock wall" will be a faux avalanch. Joint compound is in no way the correct material for what you did.
Tags
chipboard , faux finish , help!!! , joint compound , plyboard
Latex self leveling compound for wooden floor Big-Foot Flooring 3 08-13-2012 11:21 AM
Used spackle instead of joint compound on a wallboard repair--help TytusDwn General DIY Discussions 4 10-25-2009 03:43 PM
Looking for Materials Joint Compound WON'T Stick to. Lovegasoline Building & Construction 5 10-21-2009 10:22 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
