Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-28-2010, 12:09 AM   #1
Joining PVC and ABS
I got a new bathtub that came with PVC pipes but my house has ABS piping, should I connect the two by using the rubber no hub coupling? There's an "All purpose cement" for sale in big box store for ABS, CPVC, PVC. Can I glue the ABS and PVC pipe directly with this cement? Which way is better ? Thanks.
A picture is worth a thousand words.
Stephen S. is offline   Reply With Quote
Old 04-28-2010, 12:23 AM   #2
Military Mom of 4
Snav's Avatar
Joining PVC and ABS
Yes, your PVC cement will work for your connections if it states that it can be used on ABS, etc.
Flexible rubber couplings are ideally used when your old and new pipe are of differing diameters due to wall thickness, etc. You can use it for your purpose if you'd like but 3" or 4" couplings usually cost more than a traditional ABS or PVC coupling.
You cannot use PVC cement on CPVC, though (which doesn't really relate to your situation - but it's a case in which content does matter - take future note)
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
