Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-12-2005, 06:26 PM   #1
Island Hood Vent Centering Problems
I'm new here (First Time Home Buyer) and I'm renovating my kitchen. I think this is the correct forum if its not steer me the right direction.
I have ripped out my kitchen cabinets which held an under cabinet hood vent (above my stove obviously). I'm also going to remove the wall the hood vent was on. So my problem is that I want to install a Chimney style Hood Vent (this one) but I have a beam right through the center of when the exhaust vent for the Chimeny should go (the old one was 4 inches over). Anyone know a good solution to this problem? I can't move the stove.
any suggestions appreciated
Dana
Dana is offline   Reply With Quote
Old 07-13-2005, 01:47 AM   #2
Contractor
DO NOT remove structural componets without professional advice!
Teetorbilt is offline   Reply With Quote
Old 07-13-2005, 08:37 AM   #3
jproffer's Avatar
If the vent is wide enough, you could just go around the beam. Cut the vent in two peices, "notch" around the beam, and patch the seam between the vent and the beam. Like I said..IF the vent is wide enough, the air will still flow past it.
jproffer is offline   Reply With Quote
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Roughed in basement vent question jeffgator Plumbing 5 01-27-2007 12:48 PM
Ridge Vent - Low-pitched roof? brianp Roofing 2 05-08-2006 09:32 PM
