Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-29-2010, 10:39 PM   #1
Iron railing question
Hello, I have iron railings in my house and I would like to re-do them. THey were white, but I stripped the paint and painted them oil rubbed bronze, which was a huge improvement. Now, I would like to add a wooden top to them. I would like to keep the iron posts, but add the wooden rails like they sell in home depot. I really don't want to cut the rails off and attach the wood directly to the posts. I was wondering if they have some kind of system that has a groove in the bottom of the rail so it will fit over the existing iron rail. Any ideas are greatly appreciated. Thanks
joeg679 is offline   Reply With Quote
Old 01-30-2010, 07:36 AM   #2
Super Moderator
You will probably need to do this on your own.
Should not be to difficult,However you will need to find a friend with a table saw and dado blades,to cut the groove.
A router with a straight cutting bit and an edge guide would do the same thing-Just a bit slower.
Let's see if someone else has a suggestion.---Mike---
Old 01-30-2010, 07:58 AM   #3
sdsester's Avatar
Be sure and sight them, especially if buying at a box store so you end up with a relatively square edge to work with. You may have to go through a pile to get straight ones at HD. They just heep them in a pile or in the bin when they come in with noone culling out even the worst.
I would either dado cut or router them. Will not take long. How are you going to fasten them? Sure a box store is where you want to get the material? A building supply or lumber yard might have better quality material and different options.
sdsester is online now   Reply With Quote
Old 01-30-2010, 11:21 AM   #4
Thanks guys, I am not sure how I would fasten them yet. Also, I would most likely buy them at a lumber yard, I was just using Home Depot as an example, because we have all been there.
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
