Intrusions In Back Of House For Siding - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 11:17 AM   #1
Rewards Points: 150
Intrusions in back of house for siding
How do you handle the intrusions thru the siding for various items,,,like meter socket-that wont be flat on lapped siding,,,a/c disconnect box,same deal,telephone box,same deal,,,AND anchor for overhead wires(BIG honkin screw there,,,silicone caulking on all screws?? PLUS there are a lot of holding bracket screws for wires running hither and yon.
Main question,sort of,,,does the power company usually help one out with removing and replacing meter socket?? OR is this electrician hire job???? It would always be HOT since it contains the drop from pole!! AND doesnt the drop from the anchor down to meter socket supposed to be in conduit?? just BIG exposed wire now. Guess I am used to seeing weatherhead and conduit!!Thanks for any help here with the boxes and uneven lap siding now!!Just want to do things RIGHT the first time,dont have time to redo them!!
OR do you use one of those siding boxes like for outside faucets??for all boxes??
justdon is offline   Reply With Quote
Old 04-02-2008, 01:47 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Build bases, or purchase bases for specific mounting needs.
You can use 3/4" stock or thicker 5/4" stock.
When you have a stationary item, you can make your base, then cut it in half, then install it. Patch the cut line, and paint (In the 4th picture with the vent pipes, that is how the bases were fabricated).
Examples:
The following examples of bases, I would have preferred our workers use thicker 5/4" stock, but you get the idea:
In Most towns in my region, an electrician is required to pull a permit and do the removal and reconnection. It's a safety concern.
As stated, you can purchase pre-made bases, or fabricate your own.
- Build Well -
Old 04-02-2008, 02:44 PM   #3
What's going on with the dripedge in the second picture?
jerryh3 is offline   Reply With Quote
Old 04-02-2008, 03:19 PM   #4
Ohhh, you don't even know the half of that job. This was a "Handy-Home-Owner-Special" (Not that all owners do that kind of work, this guy had no clue).
This was a re-siding and new window job. I knew we were going to run into alot of issues with this house before we even started it. Those facts were included in the contract and all our discussions before any agreements, and prior to job start. Almost every single SF of the exterior required custom alteration work, before the new siding could be installed.
The previous owner of the home, had performed years of butchery on this poor defenseless house. The current owners have been improving it over the last several years.
The previous guy had also layered so much siding over the exterior, that it went beyond the window casings. When when we removed the multiple layers of siding, the gable roof lines were over-extended. We had to remove the old roof drip edge, cut the roof shingles back, and install new drip edges. What you saw in that picture was the work in progress.
Same area, Before:
Garage, had no sheathing on the exterior. This was after we removed the old siding:
Is this how you frame and insulate a wall?
Is this how to install step flashing?
We fixed everything that we found wrong, which was alot. The Home Owners were very happy. That poor house...
(To the OP: sorry about the thread hijack)
- Build Well -
Old 04-05-2008, 07:55 PM   #5
I'm going through the same thing. My house is around 80 years old. It has had a few additions, roofs, electrical/plumbing upgrades (alterations, rather). I'm slowing working room to room to try to get everything in decent shape.
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Sealing exterior wall from inside the house? BigJimmy Building & Construction 6 03-20-2007 10:16 PM
Need advice and assurance on house issues! Leikela General DIY Discussions 3 12-04-2006 11:10 PM
Sloping Floor and back half of the house. Help! mikeinfrisco Building & Construction 1 01-22-2005 09:50 AM
