Interior Wall For Mounting Tv - Nails Vs Screws - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 03:35 PM   #1
Interior wall for mounting tv - nails vs screws
Hi everyone
I am building an interior wall to hold a 40" tv, which combined with the weight of the mount itself, we're looking at approx. 80lbs.
In framing the wall, should I be using nails or screws in it's construction?
In reading a few other posts, someone else recommended putting sheets of plywood under the drywall on the side that the TV will be mounted on for additional support...can anyone also weigh in on that suggestion? If this is a good idea, would i be going with 1/4" or 1/2" ply? 1/2" seems a little excessive to me but I'm sure someone here would have much better insight.
Any advice or tips would be greatly appreciated.
Thanks everyone.
Dean
iwannabeer is offline   Reply With Quote
Old 03-21-2012, 03:51 PM   #2
Anytime you frame you Should use nails but if you want to screw them you should use a 3" deck type screw. NOT a Sheetrock type screw. Instead of plywood I would block where the tv is going so that you can screw in anywhere you need to. Make sure you secure the top and bottom well
robs660 is offline   Reply With Quote
The Following User Says Thank You to robs660 For This Useful Post:
iwannabeer (03-21-2012)
Old 03-21-2012, 04:25 PM   #3
Just a DIY guy
I agrees with robs660. I don't see how plywood is going to help much, and you would have to do the entire wall so the drywall will be even.
You want your mount to go into studs/blocking, not plywood, so the cross-blocking is a good idea, especially if you can figure out the level where you will be placing the mount. In fact, since it is only for the TV, you can mount the blocking so the broad face of the lumber is against the drywall, as that will be stronger in a vertical direction and has the added advantage of giving a larger surface to fasten the mount.
80 pounds is not all that much. A large mirror will weigh that much, and people mount those on walls every day.
Heck, they sell picture hangers that hold 100 pounds in drywall alone.
http://www.ooks.com/p-216-ook-100-lbs-pro-hangers.aspx
M3 Pete is offline   Reply With Quote
Old 03-21-2012, 04:32 PM   #4
thanks guys...much appreciated...and making a ton of sense.
obviously just don't need to wake up to the crash of a wall coming down!
thanks again!
Used the wrong nails. ndmeier Remodeling 10 02-18-2012 11:42 PM
Screws or nails in dbl layer of OSB soggycashew General DIY Discussions 6 02-18-2012 02:38 PM
Forgot to use galvanized nails... healeypd Building & Construction 8 05-12-2009 10:10 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
