Interior Door Too Wide - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 07:43 AM   #1
Interior door too wide
Hi I want to move 1 of my interior doors to another doorway but the door is 3 inches too wide for the opening, I'm new on here so would appreciate any suggestions, thanks
Dave39 is offline   Reply With Quote
Old 12-09-2012, 07:59 AM   #2
Rewards Points: 12,802
Buy a new prehing door the right size, or just reframe the opening to fit the door, and fix the drywall and trim.
Old 12-09-2012, 08:00 AM   #3
DIY staff
Rewards Points: 7,174
You need a smaller door---or a bigger opening----
That 3" is to much to trim off the door---so that's not an option---I will be simplest to get another door of the right size---is this an antique door or a more common one that can still be purchaced in a lumber yard?
Old 12-09-2012, 08:40 AM   #4
Unhappy
Door too big
Thanx for your advice looks like I'm getting a smaller door, cheers
Old 12-09-2012, 08:42 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
if you want to expand the opening you will first need to determine if the wall the door is to be located in is a load bearing wall and proceed from there. The type of wall and the load placed on the wall from above will be the most important aspect.
hand drive is offline   Reply With Quote
Hanging a chandelier on a 3.5" wide wood beam diyjames2786 Electrical 2 07-24-2012 08:07 AM
Double wide roof construction / ventilation issue cgrfish Building & Construction 5 05-30-2012 11:21 PM
Any way to put a 33" wide sink in a 38" wide hole? Natalie559 Plumbing 4 03-05-2012 08:02 PM
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 04:51 PM
engineered flooring-gap along last wall too wide golfgirl Flooring 5 12-17-2010 09:14 PM
