Interior Door Keeps Springing Back. - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-19-2013, 12:49 PM   #1
Interior door keeps springing back.
I am trying to replace the interior doors in my house. The door that I installed fits the jamb but it keeps springing back upon closing,. Can anybody give me some insight on what I should do to rectify this problem? Any help will be appreciated. Thanks.
Lenville
lenville is offline   Reply With Quote
Old 08-19-2013, 01:21 PM   #2
DIY staff
Rewards Points: 7,174
Prehung doors with new jams or new doors into existing jams?
Old 08-19-2013, 01:55 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
is the wall plumb.. if it is it sounds like its hinge bound
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (08-19-2013)
Old 08-19-2013, 02:00 PM   #4
interior door keeps springing.back
New doors existing.jambs.
Old 08-19-2013, 03:12 PM   #5
The.wall.is plumb.
Old 08-19-2013, 05:07 PM   #6
kwikfishron's Avatar
Rewards Points: 576
Look when you close the door to see if the hinge side of the door is coming in contact with the stop before the door is fully closed.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
joecaption (08-27-2013)
Old 08-19-2013, 05:11 PM   #7
DIY staff
The door is hinge bound---there are several causes---
1.The hinge mortice is to deep--shim out the hinge with a playing card or two---
2 The jamb is twisted so that the edge of the door hits the jamb before the door is fully closed----remove the casing and re-shim the jamb so it is not twisted.---you could cheat and shim the hinge only on the pin side---
3. door is hitting the stop molding---remove and reinstall the stop in the proper position
4. something else that might be seen if you posted a picture or two.
---Mike-----
Old 08-19-2013, 05:12 PM   #8
DIY staff
Ron types faster-----
Old 08-20-2013, 11:59 AM   #9
yes it is coming into contact with the stop about 4" from completing closure.
The Following User Says Thank You to lenville For This Useful Post:
oh'mike (08-20-2013)
Old 08-21-2013, 04:47 PM   #10
Rewards Points: 576
So do you have the fix figured out?
Old 08-21-2013, 05:27 PM   #11
[QUOTE=kwikfishron;1232392]So do you have the fix figured out?[/UOTE]
Removed stop
.didnt.help
Going to.shim door hinge. Ill let u know result.
oh'mike (08-21-2013)
Old 08-27-2013, 10:29 AM   #12
[QUOTE=lenville;1232406]
Removed stop
.didnt.help
I shimmed the door hinge and it worked.
Thanks for your.time.
Len
Tags
installation , interior door
Back filling a hole in lawn Master Brian Landscaping & Lawn Care 2 06-22-2013 11:47 AM
To back butter or not to back butter? fpr4 Tiling, ceramics, marble 54 05-13-2013 03:18 PM
Sump Pump Discharge and drain Back dukeboy633 Plumbing 7 04-26-2013 01:19 PM
Re-shaping back yard, tilling and other questions fox_forma Landscaping & Lawn Care 12 03-15-2011 04:51 AM
back button not working joed Site Help and Suggestions 9 11-12-2008 12:08 AM
