Intalling French Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 10:29 AM   #1
intalling french door
I would like to know the properway to install a frech door, Im taking out a existing 36'' window and wall and a existing 36'' door that total the with of the french door the wall is a exteior block wall and has stucco on the out sidek, how do I go about framing in the door ? do I pour a cement header or use wood and stucco the outside ? Jim
brewhouse is offline   Reply With Quote
Old 12-01-2008, 01:50 AM   #2
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
The french door should have the rough opening dimensions so you know how big to frame the opening.
Being its an exterior door and your gonna be spanning 6'+ your gonna need a good size header, are floor joists resting above this opening ?
Posting a picture would help out people answer your questions better.
_
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 12-01-2008, 09:16 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
This is no small project. Especially because of the siding material (stucco).
Some of the basic steps, without all the minutia (smaller details):
Work requires getting a building permit. To get the permit, you will need to show the new framing details.
Measuring and marking off of the area to be removed and re-framed.
Temporary supporting of your overhead joists above that area.
Pre-assembly of the new header.
Removal of areas of the plaster/sheetrock.
Removal of old framing with minimal damage to the exterior sheathing and stucco, if possible.
Installation of the new header and framing. Inspection
Installation of new door: plumb, square, level.
Insulation. Inspection
Exterior: Cutting into the stucco and installation of drip cap type flashing.
Installation of exterior casing and additional stucco work.
Sheetrock/plaster.
Interior finish trim
Flooring tie-in and threshold work.
Paint work.
etc, etc...
If you are lost on such details, you may need to higher this out to a reputable contractor. Make sure that they have experience in doing this kind of work, with references of happy customers, etc, etc...
- Build Well -
Issue with Anderson French Door. Help Please. dorothyolive Building & Construction 21 05-19-2014 11:18 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
New exterior french door install in a stucco wall lightninrodman Building & Construction 2 06-30-2007 12:08 PM
