Insulation Vapor Barrier - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 12:34 PM   #1
Insulation vapor barrier
We are currently remodeling the master bedroom in our 50+ yr old house and found that the bat insulation (on the exterior walls) behind the old drywall was slightly damp and deteriorating - so much that it took off the black paper behind it when we removed it from the walls. (I'm assuming this is some sort of vapor barrier correct?) I plan on using normal paper-faced bat insulation to replace it, but should I replace the vapor barrier behind it as well? The old drywall appeared to have water damage throughout, which was probably from the damp insulation (no vapor barrier between them).
I've heard that using two vapor barriers can actually be a bad idea, as it will trap moisture between them and to just use one barrier, against the drywall.
NOTE: Not sure if any of this matters, but the old drywall was covered up with paneling by the previous owner, and the outer walls are horizontal 1x6's with wood siding (which the previous owners covered up with vinyl siding).
(photos attached)
Insulation vapor barrier-17937_509892027089_195800456_30417428_1004721_n.jpg   Insulation vapor barrier-17937_509892076989_195800456_30417438_4155708_n.jpg
DIYminer is offline   Reply With Quote
Old 01-04-2010, 02:38 PM   #2
WindowTreatment Installer
We just had our Basement finished. Contractor used rolls of paper insulation and for a vapor barrier they installed clear plastic sheeting over the insulating. I live in Northern Illinois, not sure if climate has anything to do with type of barrier. You might check with your county for local codes.
bobtheblindguy is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
