Insulation In Rennovation...am I Correct? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 04:47 PM   #1
DIY Expert in Training!
Insulation in rennovation...am I correct?
Quick background...I live in a split level home. In January I will start a project in which I will gut the garage (living space above and adjacent). Once gutted I am sectioning off the back 1/3 and adding a home office. My place was to add R19 on the exterior wall, frame along the cinderblock wall and add R13 to all interior walls and R30 to the ceiling. I read that unfaced with a 6 mil vapor barrier is more effective. Am I correct on my plan?
Oh yeah, my home is outside of Philadelphia.
gone_fishing is offline   Reply With Quote
Old 11-16-2008, 06:13 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
sounds as tho you did your home work. Just make sure you have the R-19 In a 2x6 wall. Over lap your seems and tape them. BOB
Old 11-16-2008, 06:38 PM   #3
The exterior wall is 2x4...do I use R13 because of that?
Old 11-16-2008, 08:48 PM   #4
Rewards Points: 24
2x4=R-13, When you try to fit to much insulation in a wall and compress it you actually are hurting the R value.
ponch37300 is offline   Reply With Quote
Old 11-17-2008, 04:34 AM   #5
buletbob's Avatar
gonefishing , Ponch is correct. even in the ceiling it will have an effect with R-30 in a 2x6 ceiling beam bay. in that case I install r-19 unfaced and then go over it in the other direction with the R-30 keeping the sides of the insulation tight. The Idea is to not expose the sides of the insulation or else it cuts down on its performance.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
