Insulation Over House-wrap? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 09:41 AM   #1
insulation over house-wrap?
Hi all,
Looking for your opinion on this. I'm in the process of removing the lap siding from our home and will be recovering with vinyl (hopefully before it gets really cold around here). Anyway, in talking with others and doing some research, there appears to be a split on what is the desired method.
Options I've seen mentioned include:
A: House-wrap only, then the vinyl.
B: insulation board only, then vinyl.
C: House-wrap, insulation board then vinyl.
D: Insulation, house-wrap and finally the vinyl.
In our climate, the little bit of extra protection offered by the insulation is moot, as I'd rather do it proper and better insulate inside the walls if needed, as opposed to relying on either insulation board or fanfold with their minimal R-values. The current underlayment is not OSB, but rather a substance that resembles almost compressed sawdust between two layers of tar paper (does that sound familiar to anyone), which appears to be a fairly flat surface to work with.
Any thoughts on the best procedure going forward? Thanks!
H8Mondays is offline   Reply With Quote
Old 11-09-2010, 11:38 PM   #2
Registered User
Rewards Points: 5,216
What type of rigid foam board? XPS, Poliso, ?
Use a lower perm rating like Typar rather than Tyvek for your "heating mainly" climate location.
Gary
Where to buy duct insulation wrap? datanewb HVAC 3 11-16-2010 01:44 PM
Rigid Foam Insulation over existing wood siding Hexar Building & Construction 30 04-23-2010 08:15 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
house wrap or foam baker board first. fricandfrac Building & Construction 3 06-07-2009 07:16 PM
house wrap? Neil_K Building & Construction 3 12-22-2004 10:14 PM
