Insulation Odor - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 10:18 AM   #1
Rewards Points: 26
Insulation odor
Hi,
I'm about to order insulation for the house I'm building. After some reading I see that many people have been complaining about the smell of the Owens Corning batt insulation.
OC Switched to using a bio based formula in 2011 which is what produce the "burnt caramel" smell. Supposedly that smell can linger for weeks or months.
Have anyone recently installed these OC batts? If so, are they still that smelly or it's been corrected? If so, what insulation brand would be a better choice?
Thankful for any input!
tornstrom is offline   Reply With Quote
The Following User Says Thank You to tornstrom For This Useful Post:
Gary in WA (10-06-2013)
Old 10-06-2013, 10:32 AM   #2
Rewards Points: 236
Roxul
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 10-09-2013, 10:08 AM   #3
Rewards Points: 79
I just did abed room that was down to the studs with Roxul. First time with that stuff and I would never use any other typed cavity batt. What a pleasure to work with and good r value too.
eclark is offline   Reply With Quote
Old 10-09-2013, 07:41 PM   #4
Rewards Points: 236
the guys here had to really talk me into roxul. but i am so glad they did.
Old 10-10-2013, 07:41 AM   #5
Rewards Points: 2,634
That smell is only present on defective insulation.
Both fiberglass and rock-wool insulations use a bit of "binder" to hold the fibers together. If the binder does not cure fully, it can have an odor. You can find anecdotes of this occurring for both fiberglass and rock-wool. The traditional binder pretty nasty and includes formaldehyde. At least that "bio" binder does not (or at least, is not supposed to have) the nasty chemicals that the traditional binders have. Often described as a "burnt sugar" smell rather than the "chemical" smell of the traditional binders.
SPS-1 is offline   Reply With Quote
Tags
insulation , odor , owens corning
Odd odor from insulation GARoss Insulation 7 03-11-2014 12:10 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Spray foam insulation odor Ranger1227 Insulation 6 02-14-2012 11:53 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
