Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-14-2010, 02:49 PM   #1
Insulation for a mud room floor?
Hi all,
First time poster and first time home owner (1927 fix me up before i fall down special)
I have a mudroom off the back of the house that is elevated about 3' off the ground. I want to insulate underneath the floor and close it off to the elements. I was wondering if once I got the insulation up should I put a vapor barrier and enclose it with pressure treated plywood?
Leo
Leodin is offline   Reply With Quote
Old 01-17-2010, 04:30 PM   #2
Drywall contractor
Vapor barrier won't hurt anything and p.t. plywood is overkill. Regular plywood properly caulked and painted will serve the purpose...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-17-2010, 04:36 PM   #3
if you use reg ply put vapor barrier on ground also.imo
Old 01-18-2010, 07:50 AM   #4
Thanks for the info guys appreciate it!
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
floor strength in room? stirling84 Building & Construction 2 03-03-2009 04:38 PM
1.75" room / floor transition MrLinux Flooring 1 03-11-2008 03:19 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
