Insulation Installation Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-21-2010, 03:11 PM   #1
My ceiling use web joist 24" O.C. with an opening of about 20.5 inches. I purchased roxul mineral insulation for the 24 O.C, but is 24" wide so won't fit in the opening between 2 studs.
Since I have to cut the insulation, what should the width be? 20.5", 21.5" or?
Also, the wall sorrounding the room use 2x4 staggered studs with 2x6 plates, leaving a clearance of 2" in the middle on the plate. Would be ok to use 3.5" wide insulation. By code I'm required to use R21.
Thank you.
avtck is offline   Reply With Quote
Rafter vents & insulation question k.kuenn Roofing/Siding 15 01-30-2011 12:34 AM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
basement insulation question benp Building & Construction 2 03-24-2008 11:46 AM
attic/wall insulation question jasonr26 General DIY Discussions 2 07-11-2006 07:59 AM
