Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-03-2010, 10:42 AM   #1
Dick
Insulation between furring strips
I have an outside wall in an apartment that I am refurbishing that represents around 144 sq. feet of freezing cold. The plaster has failed down to the brown coat. I've decided to attach furring strips - 3/4" deep, and need to know what type of insulation to put between the strips before skinning over with the drywall. There is a product called Styro at a Big Box but it only has around R value of 4. Any suggestions about what to use would be greatly appreciated. BTW, should I put down a plastic barrier first?
Thanks.
Dick
RMCarner is offline   Reply With Quote
Old 02-03-2010, 10:50 AM   #2
Xtreme DIY'r
If you want proper insulation install at least 2" rigid for R10
Old 02-03-2010, 11:04 AM   #3
Dick
I was hoping not to push the space out that far... This is a small efficiency apartment. 2" rigid would imply that I really almost need to frame out the wall...
Dick
Old 02-03-2010, 04:22 PM   #4
Remove the remaining plaster and put batts in the stud cavities. Putting furring strips over a brown coat makes no sense, especially if you also want to insulate the space.
Ron
Old 02-03-2010, 08:46 PM   #5
Dick
Ron
Wish there were stud cavities.. What I'm looking at goes back to maybe the 1880's. I could be wrong, but I believe this outside wall is comprised of two layers of brick, lath, and three layers of plaster. It appears that someone attempted to reapply a thin coat in the 1920's or so, but I'm not absolutely sure about that. There isn't a stud in this entire building facing the outside.
This is a rental unit. I need to find a solution that isn't necessarily the best but gets me in and out in a reasonable amount of time and price wise. I decided to go with 5/4 furring strips and 1" Tuff-R that I got at the Box Store. For what it's worth, the R value of this stuff is between 5-6. Better than nothing which is what is there now. Plus, I deal with the cosmetic issues by covering the wall with drywall. Comments?
Dick
Old 02-03-2010, 09:19 PM   #6
Dick
Correction: I know now that there is no lath. Rather what I have are 3 coats - a render layer, a floating layer, and a setting layer. Deterioration is evident all the way down and into the render layer. Fossil fuel was so cheap back then, I guess you could get away without any insulation to speak of.
Dick
Old 02-03-2010, 11:00 PM   #7
Moderator
R-5 outside sheathing on an empty wall if in Lancaster, PA: http://www.ornl.gov/sci/roofs+walls/...on/ins_16.html
The inspector may buy it. If you could leave an air space------- (2) System R-value is the sum of the product R-value plus additional R-value calculated when the aluminum foil surface is installed next to a non-ventilated 3/4" air space (R-value = 2.8). http://www.dow.com/PublishedLiteratu...romPage=GetDoc
Be safe, Gary
Clothes taking longer to dry?
Old 02-04-2010, 08:25 AM   #8
Dick
Very useful source. Thanks.
Not following you here. The plan (not absolutely set in concrete yet..) was to attached the furring strips to the existing plaster then cut the Tuff-R to fit - shiny side toward the outside. Then cover with sheetrock. In the link you provided above I found the following statement: "It is sometimes feasible to install rigid insulation on the outdoor side of masonry sidewalls such as concrete block or poured concrete.However, if that is not an option, you can use rigid insulation boards or batts to insulate the interior of masonry walls. To install boards, wood furring strips should be fastened to the wall first. These strips provide a nailing base for attaching interior finishes over the insulation. Fire safety codes require that a gypsum board finish, at least 1/2 inch thick, be placed over plastic foam insulation. The gypsum board must be attached to the wood furring strips or underlying masonry using nails or screws."
If I get your drift, what you seem to be saying is that I am going to take a hit on the effective R-value if I do not somehow include an airspace. How do I do that without at the same time losing touch with my original goal, which was to minimize space lose? Lancaster has more old buildings per capita than any other city in the US. I know of several contractors that use this technique if they are constrained by a budgetary process. I dunno, I'm all ears for other ideas, but I am also constrained that way as well. Thanks.
Dick
Old 02-05-2010, 12:26 AM   #9
Moderator
What I meant was, check with your local building department for the required R-value. If they will accept what you have planned, as the foil is vapor impermeable (0.003): http://www.ornl.gov/sci/roofs+walls/...papers/143.pdf http://fire.nist.gov/bfrlpubs/build96/PDF/b96086.pdf
Be safe, Gary
Old 02-05-2010, 07:25 AM   #10
Dick
Okay, Gary Thanks.
Dick
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Insulation and furring strips question tpagel Building & Construction 6 11-22-2009 12:46 AM
Furring strips on peaked roof zantar Building & Construction 6 11-18-2009 10:46 AM
Best furring strips? J187 Building & Construction 5 06-03-2006 10:41 AM
