Insulating My Attic - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 01:39 PM   #1
insulating my attic
Where and how should I insulate my attic?
Do I place insulation on the ceilings?
The floor is finished w/wood flooring. If I place insulation on top of the existing flooring, can I then place something above the insulation so that I can use the space for storage?
Lydia K is offline   Reply With Quote
Old 12-07-2010, 04:49 PM   #2
Lydia, check to see if you already have insulation in your roof rafters. If not, then this would be the best area for insulating your attic and using the floor for storage. As for insulation, it will all depend on the R-value that you are looking for. You can also use ridged insulation panels on the floor if need be. Make sure that you get dense foam panel for that.
http://www.yourfamilyhandyman.com
Kurtzilla is offline   Reply With Quote
Insulating Attic Floor - Which? HandyFrank Building & Construction 3 11-24-2010 01:27 PM
Insulating the garage attic. CZ4diy Building & Construction 3 11-10-2010 10:05 PM
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
Insulating attic with rigid foam giannit Building & Construction 0 01-08-2010 10:39 AM
Insulating Semi-Finished Attic... Need info scrupul0us General DIY Discussions 8 12-03-2008 01:25 PM
