Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-09-2009, 09:00 AM   #1
Insulating exterior wall during partial renovation?
I'm going to remove tile & mortar bed from the lower half of an exterior wall in one of my bathrooms, and replace it with drywall. I plan to put fiberglass insulation where I can in the studs.
My question is, should I put up a vapor barrier too (I live in N GA), or there's no point unless I'm putting up a vapor barrier over the entire wall?
walkman is offline   Reply With Quote
Old 12-09-2009, 09:40 AM   #2
gravity always wins
I would hope you're not going to replace with drywall and then tile over it. Use a tile backer board and waterproof it. Then install the tile. That will take care of your vapor retarder issue. It will be built in as part of the tile/waterproofing system.
Old 12-09-2009, 11:45 AM   #3
I'm removing existing tile, mortar bed and metal lathe from the wall. Drywall will be the finish surface.
Old 12-09-2009, 09:27 PM   #4
gravity always wins
Then I would use a vapor retarder over the insulation and if it's in a bath, I would use a mold resistant drywall like Densarmor,
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
worth insulating pipes? wombosi HVAC 4 02-15-2009 07:32 PM
