Insulating Exterior Bathroom Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 10:10 AM   #1
Insulating exterior bathroom wall
I am remodeling my bathroom with a new alcove tub. The short wall of the tub will be on an outside wall that currently has batt faced insulation. I will be using Kerdi over Durock on the three tub surround walls.
Is it necessary to change insulation to un-faced or cut slits in the faced insulation on this exterior wall.
I am concerned about creating a moisture sandwich between the kerdi and the faced insulation.
I am located in Southern NY by New York City.
Any help would be appreciated.
Thank you...
tsayles is offline   Reply With Quote
Old 12-02-2012, 10:22 AM   #2
Retired from the grind
Rewards Points: 6,652
Really depends on where you are located. Otherwise, you will be fine as is.
Old 12-03-2012, 01:59 PM   #3
Special User
Rewards Points: 1,230
That's a good question, I'll be doing the same thing soon (albeit in Idaho, but we both get cold winters). My assumption would be it shouldn't matter a whole lot either way, because if you have moisture coming through the kerdi and durock then you have a problem that batt facing will neither help or harm. But I will defer to the wisdom of others...
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Basement wall insulating Alyson Building & Construction 5 12-03-2011 08:50 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Insulating existing basement wall tigereye Remodeling 1 12-28-2009 06:24 AM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 10:23 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
