-   -   Insulating exterior bathroom wall (http://www.diychatroom.com/f15/insulating-exterior-bathroom-wall-165354/)
tsayles 12-02-2012 10:10 AM
I am remodeling my bathroom with a new alcove tub. The short wall of the tub will be on an outside wall that currently has batt faced insulation. I will be using Kerdi over Durock on the three tub surround walls.
Is it necessary to change insulation to un-faced or cut slits in the faced insulation on this exterior wall.
I am concerned about creating a moisture sandwich between the kerdi and the faced insulation.
I am located in Southern NY by New York City.
Any help would be appreciated.
Thank you...
gregzoll 12-02-2012 10:22 AM
Really depends on where you are located. Otherwise, you will be fine as is.
tylernt 12-03-2012 01:59 PM
That's a good question, I'll be doing the same thing soon (albeit in Idaho, but we both get cold winters). My assumption would be it shouldn't matter a whole lot either way, because if you have moisture coming through the kerdi and durock then you have a problem that batt facing will neither help or harm. But I will defer to the wisdom of others...
