Insulating Bathtub? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-08-2013, 01:43 PM   #1
Insulating bathtub?
Will be remodeling bathroom soon. I'm going with an acrylic tub and was wondering what is the procedure for insulating and sound-deadening underneath tub before install? Is it a spray application of some kind? Thanks in advance.
SH140 is offline   Reply With Quote
Old 02-08-2013, 02:35 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
The proper installation instructions should come with the new tub. Have you bought it yet?
brockmiera is offline   Reply With Quote
Old 02-08-2013, 03:02 PM   #3
Rewards Points: 3,130
In 40 years of DIYing, I've never heard of insulating a tub. Non-metallic tubs were often set in a bed of mortar to prevent creaking, but that's not common any more.
Old 02-09-2013, 12:15 PM   #4
No, I haven't purchased the tub yet...........On other sites I've read posts that alluded to the installer putting some kind of "insulation" on tub before install to improve heat retention quality (and also the noise factor), but they didn't say what product they used. I assumed it was a more common practice than it seems to be......But I will be setting the tub in a mortar base (I've heard too many stories of tubs that flex and creak when you get in it). I want to get this right the first time, even if it's overkill.
Old 02-09-2013, 12:20 PM   #5
Rewards Points: 13,468
A quality buld tub will be self supporting, some even come with a thick foam pad it sits on.
Old 02-09-2013, 04:13 PM   #6
GBrackins's Avatar
Rewards Points: 2,108
we have used spray foam in a bed to sit a tub in/on. Foam pad would be much easier.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-10-2013, 01:21 PM   #7
I realize that the bottom of tub will sit on a mortar bed for support of the tub bottom. What I'm trying to find out is, to get extra insulation value, does anyone put any kind of insulation in the "cavity" of the tub? (not the bottom where the mortar will be)....I'm beginning to wonder if I really heard about doing this somewhere, or if I just dreamed it up on my own..
Bathtub/ shower tiling buju Tiling, ceramics, marble 37 08-07-2012 07:03 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
