Insulating Basement Walls That Are Sealed - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 03:13 PM   #1
Question
insulating basement walls that are sealed
ok so im remodeling a basement for a friend, ive sealed the wall with the zinsser watertite. do i need a vapor barrier on the wall before installing fiber glass insulation??? also another question im insulating the celiings with r13 kraft faced fiberglass insulation, when instaling above heating ducts (supply ducts not return) i know the paper can not be close to teh ducting, so can i cut the kraft facing off in the areas and it still be a functional sound and heat barrier, and will it be safe?
mcarlson is offline   Reply With Quote
Old 01-26-2011, 11:25 AM   #2
Rewards Points: 5,336
Why can't the paper be close to the heat ducts? What do you think will happen?
They have special insulation used for sound deadening.
Ron
Old 01-26-2011, 11:29 AM   #3
Duplicate post
Old 01-26-2011, 11:30 AM   #4
Experienced
Jackofall1's Avatar
You might want to check the correct way to insulate basement walls.
http://www.buildingscience.com/docum...ent-insulation
As for the ceiling insulation, you don't need the paper anywhere on the ceiling, on a side note, FG bat is not the greatest for sound insulation.
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 01:06 AM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 09:26 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 04:42 PM
Basement half walls to full walls Basement Man Remodeling 11 03-29-2009 03:33 PM
