Insulating A Basement/crawlspace - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 08:14 PM   #1
Rewards Points: 14
Insulating a basement/crawlspace
I have an old home with a basement and crawlspace. It is freezing down there and I need to insulate it. What is the best way to do this? It dosn't have to be pretty as the space will never be used for anything but the furnace etc.
needtoknow is offline   Reply With Quote
Old 01-06-2010, 08:04 AM   #2
Remodeling Contractor
Seal along the rim joist This is the space along the perimeter and between/along the floor joists is where 10% of the heat loss occurs. Seal this area with spray foam or Roxul insulation. You cannot use fiber glass since too much moisture transfers here and will destroy the effectiveness of this type of material.
Old 01-06-2010, 11:11 AM   #3
Registered User
Rewards Points: 526
Spray foam, as Bob said, is the best way. http://www.buildingscience.com/docum...n-crawlspaces/
Be safe, Gary
Old 01-06-2010, 01:03 PM   #4
Be safe, Gary
Side question for you. How do I link my computer to all these excellent references stored on your computer?
Old 01-06-2010, 08:26 PM   #5
Registered User
Rewards Points: 526
Bob, lol. I found that one a few months ago and it was written this year! That's really good for an old timer like me.... Since off work, I have time for research and more research, between the honey-do lists.......
Be safe, Gary
Framing & Insulating basment concrete walls harddy Building & Construction 8 12-02-2009 12:04 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
Question about insulating a garage forCcanadian winters trucker Building & Construction 3 02-08-2008 05:07 AM
