Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-02-2011, 06:57 PM   #1
Insulating an addition
We have a garage that was converted into a bedroom and a hall to the basement. This room is very hot in the summer and cold in the winter. I was able to drill a hole and found no insulation between the concrete floor of the old garage and the new addition wood floor. the space between the two is about 12". Their is a main beam running down the center of the converted room and the joists run off of that. How can I add insulation to this room without ripping up all the hardwood flooring?
cbollin is offline   Reply With Quote
Old 02-03-2011, 12:59 AM   #2
Moderator
A floor plan drawing and a picture would be helpful....
No access from below?
Gary
Clothes taking longer to dry?
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Insulating and Underpinning a new addition annoyed Building & Construction 2 08-23-2009 06:04 PM
Footing/Foundation for Addition stubits Building & Construction 1 03-11-2009 02:43 PM
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing 4 09-10-2008 06:06 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 08:59 PM
