Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-11-2010, 01:40 PM   #1
insulate concrete wall above grade?
What is the recommended procedure for insulating a concrete half wall that is above grade? The concrete wall is exposed on both sides. I am in Vancouver BC.
bcbud3 is offline   Reply With Quote
Old 02-12-2010, 05:31 PM   #2
Remodeling Contractor
I will try to make this simple. hot air moves to the cold air. So in one season the air moves into the house and the other season it moves out. The only way to make this work is an air barrier that is not effected by moisture. So the answer is 2' form board or closed cell spray foam. In your area I would recommend a minimum of 4" Anything else you use will fail eventually. Also be sure to completely seal the joist space along the entire basement at the rim band. This is critical since the dew point is reached easily at that juncture and water condenses on the rim band and soaks into the floor plate and good bye house. The foam air seals and insulates. Nothing else will work as well...period!
Old 02-12-2010, 07:17 PM   #3
I have used 'foundation wrap' in my basement! It comes in a 50 foot roll and is 4' wide!
The fibre glass insulation is bonded to the vapor barrier. There's a steel strap on the bottom that is screwed to concrete with Tapcon screws and the top has a 16" apron that is stapled to the top plate and is fitted up into the joist cavity.
Old 02-12-2010, 11:29 PM   #4
Moderator
http://www.buildingscience.com/docum...Insulation.pdf
http://www.swinter.com/services/docu...Insulation.pdf
Be safe, Gary
Clothes taking longer to dry?
Old 02-13-2010, 03:07 AM   #5
so its no different than a concrete half wall below ground?
Old 02-13-2010, 07:50 AM   #6
The wall below grade will in most cases dry to the inside. the area above grade will dry to the outside. The area between the this plain needs to have a sealed thermal break
Shower pan/tile against concrete wall mgray87 Tiling, ceramics, marble 10 09-11-2009 12:50 PM
Mounting a panel to a concrete wall tigereye Electrical 4 08-21-2009 08:11 PM
How to seal a shower pan liner against a concrete foundation wall? mgray87 Kitchen & Bath Remodeling 3 08-13-2009 12:08 PM
painted concrete under the wall paper? guygood Painting 3 12-01-2007 12:57 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
