Installing Wall Unit Over An Outlet - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-03-2013, 09:24 AM   #1
Roadie
Installing wall unit over an outlet
Hi,
I live in Pennsylvania and I am installing a wall unit in my dining room. In doing so, I will be covering up an electrical outlet. Do I need to move this outlet so it is accessible, can I make it accessible through the wall unit, or can I cover it up? Thank you.
bdechill is offline   Reply With Quote
Old 12-03-2013, 10:13 AM   #2
Rewards Points: 13,764
Is this a piece of furniture, or is it being attached to the wall?
How thick is the back of the unit?
Old 12-03-2013, 10:15 AM   #3
Roadie
It is separate pieces and being attached to the wall.
Back of cabinets is about 1/4" thick.
Old 12-03-2013, 10:23 AM   #4
joed's Avatar
Rewards Points: 12,950
Since it is attached to the wall the receptacle can not be covered up. You can cut a hole in the back of the unit to expose the receptacle and be fine by electrical code.
The Following User Says Thank You to joed For This Useful Post:
gregzoll (12-03-2013)
Old 12-03-2013, 10:43 AM   #5
Roadie
Even if the receptacle will only be accessible if the cabinet doors are opened and a drawer is pulled out?
Old 12-03-2013, 03:40 PM   #6
Rewards Points: 3,130
Yes, it would still be legal.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 12-08-2013, 12:00 PM   #7
Rewards Points: 336
Actually, it depends. A building inspector told my parents that a receptacle installed inside of a cabinet on top of a bathroom vanity wasn't accessible. No drawer to pull out in that case, either; just two cabinet doors to open. I happen to disagree, but that doesn't really matter in that case.
JKeefe is offline   Reply With Quote
Old 12-08-2013, 05:35 PM   #8
Actually, the only thing it "depends" on is how knowledgeable the inspector is. I have two or three outlets inside wall cabinets, and passed inspection with no problem. In your parents' case, I would've asked (politely, of course) for referral to the code section that allegedly makes such receptacles noncompliant.
Old 12-08-2013, 09:20 PM   #9
Rewards Points: 236
i would put the wall unit where ever i felt like, however i felt like
then went and had a beer
Fix'n it is offline   Reply With Quote
Tags
electrical , outlet
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Installing outlet on existing drywalled wall Red Squirrel Electrical 19 06-05-2010 12:08 AM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
