-   -   Installing wall unit over an outlet (http://www.diychatroom.com/f15/installing-wall-unit-over-outlet-191397/)
bdechill 12-03-2013 09:24 AM
Hi,
I live in Pennsylvania and I am installing a wall unit in my dining room. In doing so, I will be covering up an electrical outlet. Do I need to move this outlet so it is accessible, can I make it accessible through the wall unit, or can I cover it up? Thank you.
joecaption 12-03-2013 10:13 AM
Is this a piece of furniture, or is it being attached to the wall?
How thick is the back of the unit?
bdechill 12-03-2013 10:15 AM
It is separate pieces and being attached to the wall.
Back of cabinets is about 1/4" thick.
joed 12-03-2013 10:23 AM
Since it is attached to the wall the receptacle can not be covered up. You can cut a hole in the back of the unit to expose the receptacle and be fine by electrical code.
bdechill 12-03-2013 10:43 AM
Even if the receptacle will only be accessible if the cabinet doors are opened and a drawer is pulled out?
md2lgyk 12-03-2013 03:40 PM
Yes, it would still be legal.
JKeefe 12-08-2013 12:00 PM
Actually, it depends. A building inspector told my parents that a receptacle installed inside of a cabinet on top of a bathroom vanity wasn't accessible. No drawer to pull out in that case, either; just two cabinet doors to open. I happen to disagree, but that doesn't really matter in that case.
md2lgyk 12-08-2013 05:35 PM
Actually, the only thing it "depends" on is how knowledgeable the inspector is. I have two or three outlets inside wall cabinets, and passed inspection with no problem. In your parents' case, I would've asked (politely, of course) for referral to the code section that allegedly makes such receptacles noncompliant.
Fix'n it 12-08-2013 09:20 PM
i would put the wall unit where ever i felt like, however i felt like :yes:
then went and had a beer :thumbup:
