Installing Wall Mounted Vanity - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 11:21 PM   #1
Installing wall mounted vanity
Behind the drywall I have 2x6 studs. I will be mounting vanity and than a heavy 32" sink. There are four brackets top and bottom.
I haver robitson #14, 3" wood screws I've been given at HD and washers. Should I get hex head screws instead of the robitson screws and use a nut driver? Is the robitson #14, 3" wood screw good enough or would something else be preferred? First I would pre-drill with a small drill bit so I don't split the 2x6 when driving it through. This is the first time doing this so i want to make sure it stays up. I have two kids so I will also install French cleat underneath. Any suggestions/help would be much appreciated.
Philj is offline   Reply With Quote
Old 04-30-2011, 08:36 AM   #2
DIY staff
Rewards Points: 7,174
You should be fine with the screws---However, The lag screws have a higher shear strength---If you feel safer using lags--go for it.
My biggest concern would be the length of the screws and the location of you water lines---
Hitting a water line could REALLY change your day!---Mike---
Old 05-03-2011, 10:15 AM   #3
Rewards Points: 5,336
Didn't the vanity come with installation instructions?
I usually just follow them.
Ron
small gap between vanity and wall, how do i screw it in? cantgetenuff Building & Construction 8 03-09-2011 11:15 AM
wall mounted residential toilet kr bennett Plumbing 10 12-05-2010 10:03 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 10:17 AM
Wall mounted scart / aerial socket miked Electrical 5 01-05-2007 05:40 PM
