-   -   installing vinyl siding over aluminum siding (http://www.diychatroom.com/f15/installing-vinyl-siding-over-aluminum-siding-76634/)
brad7359 07-19-2010 08:45 PM
is it possible to install vinyl siding over the old existing aluminum siding
Joe Carola 07-19-2010 09:12 PM
No, don't even give it a second thought. Do the right thing and take the aluminum off.
kwikfishron 07-20-2010 05:06 AM
199 Attachment(s)
I got $600+ from the scrap yard for the last aluminum siding job I tore off. That was when it was only going for .43 a lb.
Ron6519 07-20-2010 10:21 AM
That is such a bad idea on so many levels.
Ron
HomeSealed 07-21-2010 03:47 PM
Anything is possible!:jester:.... Seriously though, don't ever do that. :no:
Proby 07-21-2010 04:21 PM
They put new roofs over the old ones, why not siding :jester:
Tom Struble 07-22-2010 06:15 PM
remove it,after thinking about it you could be siding over water,trapped in the old siding
i think VSI states it must be removed
sometimes i type faster than i think,and i don't type fast
concretemasonry 07-22-2010 08:41 PM
In many areas with variable climate, you are not allowed to put new over old roofing even if you know it will shorten the ;ife and not perform well.
Granted siding is not as critical as roof fpr weatherproofing, there are other problems with trim and performance to be recognized in advance.
Vinyl over any other siding is a mistake.
Dick
Tom Struble 07-24-2010 06:28 AM
probably the reason for not allowing roof layovers has to do with the added weight,not so much the shingle performance
i agree with the pros here remove existing materials when possible
