Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-06-2007, 05:45 PM   #1
Installing a Storm Door
I live in an old house about 80 years old, but the whole house was remodeled and everything is new. I'm wanting to get storm doors in the front and back. There are just solid doors there now, both with existing transom windows above each door. I had them professionally measured and now they're saying that in order to install the storm doors, they must replace the transom windows too. I'd rather not have to do that, since they are already new. Anyone have any other options. Help!!!
matthews1977 is offline   Reply With Quote
Old 06-06-2007, 06:07 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hi,
Pictures would really help alot with your question.
- Build Well -
Old 06-06-2007, 06:25 PM   #3
Hopefully I did this right and there is a picture attached.
Thanks,
Molly
Old 06-06-2007, 06:43 PM   #4
Yes, get some more quotes on this.
- Build Well -
Old 06-09-2007, 12:40 AM   #5
The door seems to have a traditional brick molding. I don't see any reason to touch the transom window as it is not impacted by the storm door install. You need other opinions, as Atlantic stated.
Ron
More On This Topic
Hail storms are frequent occurrences that usually don't cause extensive damage. However, a severe storm with hail stones up to 3 inches in diameter can cause significant damage. If you follow some simple precautions to prepare for a hail storm, you will... Read More »
For maximum comfort and energy efficiency, you should try your best to find and eliminate any drafts in your home. These minor problems can add up to a lot of trouble over the years, especially considering the rapidly rising cost of energy. In an average... Read More »
Learn how to install a bi-fold door in this free video on home remodeling and construction. Read More »
Problem installing entry door Jemo Building & Construction 11 06-20-2009 10:39 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Installing a Door in an existing pass-through gbarron1 Building & Construction 2 03-17-2005 04:47 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
