| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Make Base Inside Corner Cuts at 45 Degree Angles With a Miter Saw
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip we are going to be demonstrating how to cut base on an inside corner with the miter saw. It is very similar to cutting the outside corner, except you will the opposite direction for... Read More »
Canon EOS 40D: Rotating Image
by Expert Village
Rotate photo by 90 degees or 180 degrees. Learn how to rotate images in the Canon EOS 40D Digital SLR camera in this free Canon photography lesson. Read More »
How to Make Base Outside Cuts With a Miter Saw
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip, we are going to demonstrate how to cut base moulding on an outside corner. By outside corner, I mean that you have a wall right here and this is the outside corner that you are going... Read More »
How to Select Chisels for Stone Carving
by eHow.com
Sculptors define the shape of their stone sculptures with chisels. Chisels come in different lengths and widths. Point, flat and tooth chisels perform a different function in the carving process. Finer pointed chisels are used for much of the intricate... Read More »
Mark & Cut the Outside Corners for Base Molding Installation
by Expert Village
I am Tim for Expert Village and we’re continuing on cutting outside corners for shoe molding. So, basically what I was saying about marking the back, you measure on the back side of your piece because that is going to be your short end and that is... Read More »
